Vertical pipe support (pvc)
MN-E
This feels like this should be an easy answer, but I haven't been able to find it...
I have new PVC running from my basement, through the 1st floor and into the 2nd floor (one 4" and one 3").
Code in my area requires vertical pipe support at each floor.
I have a roll of the nylon strapping-material; if I just loop it tightly around each stack and secure it to the nearest framing with screws, is this the correct method? Or are there plastic riser-clamps that I should use?
Thanks in advance, folks.
