adding shower
Xplorer96
New York
I have an existing 1/2 bath in the basement (raised ranch). I am going to break up the concrete and connect the new shower drain into the main which is 4 feet away. My question is, since the main acts as a vent, is that sufficient to vent the shower without adding another vent as there is no close vent to tap into? Thanks for any advice. Rob
You didn't ask, but just in case you are not aware, a shower drain is required to be 2". Tubs are OK with 1-1/2".
RE : Shower Vent
If the 2" trapped shower drain goes directly into a 3" main dwv (4feet away) does it still need a separate vent or is the 3 inch main dwv sufficient?
