Best Kitchen Sink Drain Flange
FJK
Illinois
I'm installing a new stainless steel sink for a friend. I'd like to know what is the best drain flange I can install, relative to preventing loss in appearance. I'd like to use a stainless drain flange, but have not seen any locally. Even with the cast brass flanges, the chrome finish deteriorates quickly, especially with well water. I did see one at Lowe's, cast brass, cut threads, brushed nickel finish. That's the best one I've seen so far. Any recommendations & where to buy?
Thanks, Jim
The drain flange is also called a strainer basket as well. It is a whole Assembly. as kingsotall suggested, try other stores, or even a plumbing supply. If they can not help you can find what you are looking for on-line. Dearborn Brass makes a all stainless steal body basket strainer assambly called the Shallow Cup EZ-Mount Strainer part number DB1000EZBN
One of these¿ If so it's in stainless.
Here's the link
