thermal fluid hydronic baseboards
wwimberley
As I understand it the self contained thermal fluid hydronic baseboards are not more efficient than regular baseboards because 100% of the energy is converted to heat in both. Some folks think they are more effective because they can release heat for a longer period of time, even when off, due to increased mass. Would you think that fact alone justifies the increased cost over regular baseboards?
What are some thoughts about retofitting electric in-floor heat mats under tile or engineered flooring. I presume that's a much higher cost but what are some other advantages/drawbacks of in-floor over just a good quality electric baseboard whether it's a regular electric or thermal fluid hydronic.
thanks,
Retrofitting in-floor electric heating generally means tearing up the floor first, so that can be expensive unless planning to replace it. Depending on where you live and how much heat you need, you may not be able to actually heat the room with in-floor electric. To achieve the needed amount of BTUs, the floor may become uncomfortably hot. You can certainly make the floor more comfortable with it, though. you can get 10-12 BTU/sq ft with electric. You can achieve a lot more heat transfer with hydronic, but that means a boiler. The oil in the heater will probably be a little more even, but heat is heat, and eventually it will all spread out into the room. Heating the whole floor means more even comfort, and no restrictions on where you can place furniture.
