View Full Version : PVC Wall Tube Connection
BillM
03-14-2009, 11:07 AM
Hello all.....
Please bear with me, but I've got a very basic question......
I have 1-1/2 inch PCV Wall Tube from behind vanity. I am trying to connect Plastic P-Trap to the PVC. The PVC has no threads......just straight PVC coming out of wall.
What is best way to attach connector? 1-1/2 inch connector doesn't seem to fit correctly? Is the term "Desanki" familiar? Local plumbing supplier told me that I "cut off the Desanki", when I shortened the wall pipe......so now attempting to reconnect, but standard HD plastic doesn't seem to be a 'tight' fit? Don't want a leak problem later?
What am I doing wrong?
Thanks for info...
-Bill
Gary Swart
03-14-2009, 12:08 PM
I'm just a DIYer, so admittedly there are lots of things I don't know, but I have no idea what a "Desanki" is, Google doesn't either. But, to transition from PVC pipe to a P trap, you need a threaded adapter. Smock man at HD didn't give you very good advice. You would be wise to have someone illustrate how to make this connection with actually pieces of pipe and fittings.
cwhyu2
03-14-2009, 01:25 PM
It is called a desanko or trap adapter.The term desanko comes from the man that invented it.It was his name.
BillM
03-14-2009, 01:57 PM
Thank you......I'm just back from HD......
Gary....you were right.....Smock Man did steer me wrong.....
cwhyu2......thanks for clarifying 'Desanko'.......
Bottom line - Desanko=Trap Adapter.....and that's what I ended up with......finally......
Thanks again!
03-14-2009, 04:12 PM
DeSanko, Marvel connector, waste and vent connector, trap adapter, and maybe others, all of them refer to the same thing. I am not sure that De Sanko invented it because we used them for decades before I heard his name associated with it. Which one you use depends on which part of the U.S.A. you are in.
Gary Swart
03-14-2009, 04:22 PM
Well, another day and I've learned more stuff! :)
kingsotall
03-14-2009, 05:26 PM
tomato tamato
