replacing toto toilet
imate
I have a toto drake elongated ada compliant toilet bowl. can i replace the bowl with a regular height toto drake without changing any plumbing or floor tiles or anything like that? the rough in the ada is 12" while the rough in for the regular is 10".
It depends on how they did the tile underneath...if it was done well where the tile goes all the way to underneath the flange with no gaps, then the floor surface should be okay although you may have to do some cleanup if there's any caulk (could leave an outline). If they didn't run the tile everywhere, you might have ugly holes showing.
On the Drake, to get a 10", they use a different tank as I understand it. I'm pretty sure if you swapped tanks, that 12" ADA version tank will fit on the lower one and you'd have the same gap at the rear (iow, it'd be a 12" rough-in toilet). If you just swap the entire toilet with attached tank, then you'll have the gap.
correction to replacement of toto toilet
I have a little more information to fill in. I had looked up the wrong information on the toto website. I see the drake toto non-ada size does also have a 12" rough in. So is there anything else I should be concerned about changing from ada compliant to non-ada compliant? Thank you for your previous reply.
The base then should have nearly the same footprint, so fit should be okay...if the old toilet was caulked (and it should have been), it could take some work cleaning it off. Should be a straight swap.
