Expanding foam around pipes
Blumengarten
Pennsylvania
Hi Everyone,
We've had a horrible problem with stink bugs this year, they only prevention I've heard is to try to seal up every tiny crack in your house that they may be getting in through. The bathroom is over the garage, and there's a large hole in the garage ceiling drywall where the drain pipes come down (the person who remodeled never patched the hole). The bugs may be coming in through the opening under the vanity, where the drain pipe goes into the wall, because that's open directly into the garage. The expanding foam should completely seal this hole, preventing their entry, but should I be concerned that it would make them hard to access should they ever need to be repaired or replaced? The piping is PVC and about 15 yeas old, and as far as I can tell, seems to be in good condition.
Thanks,
Joy
I don't know if the foam will keep the bugs out or not, but what do you think will happen to PVC pipe as it ages? It doesn't rust, rot, or corrode. It won't fall apart or weaken with age. If sometime there comes a need to remove the pipe or remove the foam, it came be cut out without too much effort. In other words, I see not reason not to try it, it isn't going to hurt anything, won't cost much, and can be removed if desired.
Okay thanks, that's what I wanted to know! My plumber doesn't like the makeshift repairs my husband makes because he (my plumber) says they just make his job tougher, and I didn't want to do anything without asking an expert's advice! I don't know if it will keep the bugs out, but that is a big hole. Thanks!
Just don't put so much in the hole that it expands and cracks the bottom of the vanity.
Stink Bugs? Or Box Elder Bugs?
