Pitless adapters in NC?
ncgeo
North Carolina
Does anyone know why pitless adapters are not used on wells in the Piedmont (charlotte area) of NC? I've had 2 different drillers tell me they are not allowed. Doesn't make sense; it was 12 degrees here last night so is hardly a frost-free climate. Maybe they want to keep those fake-rock manufacturers in business, since you need to cover the exposed pipe out the top of the seal with something or risk a freeze up.
Here in my part of Texas, most people do not use a pitless either. However, I have them on all of my wells. Those who have a pitless don't have to worry about freezing. Those without a pitless, try to keep some water running when it freezes. Sometimes it works, sometimes they have to call a pump man. Letting the well head freeze can be expensive. It can even cause plastic well casing to collapse, completely ruining the well, if the motor continues to run when the well head is frozen.
Leaks Possible
Here in MO they are allowed but not on a well that supplies water to a dairy barn. Heath Dept says no, might leak water around the seal.
