View Full Version : Water pressure fluctuation
JMichaux75
07-01-2005, 05:36 PM
I have been having a problem with my water pressure fluctuating. Every water faucet, sink, toilet, and shower run water fine for the first few seconds then the water pressure gets so low, water is no longer coming out of the faucet, then within a minute the water pressure slowly bulids back up to full strength. There are no air bubble when this happens. I am hoping I can do the repairs myself but, I am not sure what to repair. Any input here would be great.
Thanks!!
jadnashua
07-01-2005, 06:23 PM
Is this on a well system, city water, on hot, cold or both? Is the pipe old, new, galvanized, lead, copper? A little more info?
Gary Slusser
07-01-2005, 08:33 PM
Yes more info, like what type of pump; jet above ground or submersible in the well?
Gary
Quality Water Associates
jimbo
07-02-2005, 06:48 AM
If you are not on a well system, then your symptoms are classic for a defective main pressure regulator.
JMichaux75
07-02-2005, 10:39 AM
I am on city water and it does not matter the temperature of the water. Even my outdoor spigots have this problem. The plumbing in the house was switched from polybutylene to CPVC(flowguard gold) about 7 years ago. The house itself is twenty years old. None of my neighbors have this problem.
If it is the water pressure regulator can that be replaced by a novice do it yourselfer or is this too difficult?
Hope this helps..let me know any other questions!!
jimbo
07-02-2005, 02:09 PM
Find your PRV. If you buy the exact same brand and model, it is often a direct screw-in replacement with no piping mods. necessary.
