View Full Version : sweating chrome valve
daveydo
03-01-2009, 08:39 AM
Hello all
Has anyone any experience with sweating this type of Valve (DAHL Brothers Canada Ltd.). I'm having a heck of a time trying to remove the seat nut. I'm afraid I may cook the seals if I try to sweat it without removing them first.
Dahlman
03-01-2009, 08:51 AM
Hello all
Daveydo,
Don't try to dismantle that valve! :eek:
You will void the warranty. Just leave it in the open position when soldering and it will be fine. Trust me. I'll PM you now.
Cheers,
Dahlman
daveydo
03-01-2009, 09:17 AM
Thanks Dahlman
daveydo
03-01-2009, 01:04 PM
Hello Dahlman,
Valves are now installed as you instructed. Thanks again
That is a valve for a masochist. Everyone else uses compression valves.
Dahlman
03-01-2009, 03:08 PM
Hello Dahlman,
Anytime! :D
SewerRatz
03-01-2009, 03:33 PM
Guess I am a masochist, I prefer the sweat on valves. They do prove a challenge in sweating them on close to a wall, but with care and the right tools anything can be done and look good.
They are an even greater challenge when they have to be replaced, and even quarter turn valves WILL NEED to be replaced eventually.
SewerRatz
03-02-2009, 07:06 AM
That is when I bust out the electric soldering system. I have the one that works with my pipe thawer. Works great on removing valves as well as sweating up two two inch pipe. The one pictured below is Ridged's version that can soft solder up to 3" pipe. http://www.ridgid.com/ASSETS/12DC8C8E646F4AF4B09999F572240267/RT175_Soldering_Gun_3C.jpg
daveydo
03-03-2009, 02:58 PM
Hi all,
Thanks for the input but I perfer a sweated valve if possible.
Usuallly, I remove the stem, plug the pipe with bread & use a pencil flame torch, & watch how I orient the flame. .
When it comes to replacing them, I cut the pipe back, sand the surface, treat it to a heated bath of paste to clean out any pits that may have developed on the surface over time, & I'm good to go.
If it can't be cut, I'll sweat off the old valve, do the paste bath while rubbing vigorously with steelwool , pits again you know, bread in the hole again , & again good to go.
By the way old pipe? plenty of paste & elbow grease
If that doesn't work it's time for new pipe cause even a compression valve will probably crush it.
kingsotall
03-03-2009, 07:50 PM
How come you get all the nifty tools ratz¿!!!
http://z.about.com/d/autism/1/0/j/-/-/-/tantrum2.jpg
SewerRatz
03-03-2009, 08:05 PM
Kingsotall, you be amazed at all the junk.. erm tools I have. Acquired them over the years. My father and I can never pass up some one selling off tools.
He had a request by an apartment complex that we use this new jet-rodder they read about. He looked into the cost it was 12K at the time. He had them sign a contract having him jet-rod their lines every 6 months and he charged them a $200 rod charge each time till it was paid for. So 30 months later we dropped the rod charge and kept doing the work for another 3 years till they finally came out with portable jetters and the apartment complex bought their own. It was by National was a monster of a machine had 1" stainless steal cable with a rubber hose fed through as the inner core, and the cutter fit over the male threads of the hose and the jetter nozzle held the cutter in place. there was a twin piston pump just like the old Mustang jetters used attached to the back of the the drum which supplied a whole 800PSI. Marco makes one now. http://www.marcosnakes.com/jetforce.htm
