Rocknroj
02-27-2009, 06:52 PM
Greetings..
My Drain lines are dry fitted in muck below where the slab used to be.. My question is how clean do I need to make these to glue.. When I clean with a rag, they end up a bit rough.. I was thinking about hitting em with some 400 grit as a final clean up. Is this adviseable... How forgiving is the ABS glueing process?? I also read that the pipes slide together easier when the glue is on and may go in deeper than they want to do on the dry fitting..
Thanks in advance
Thanks in advance
