The pressure switch started to go off and on constantly,I shut the pump off and went and got a new switch.After i installed it the pump did the same thing,I then drained the water out of it and made sure the tank was not waterlogged,I put air back into it and turned the pump back on.I have it set for 50/30..Now the problem is when I run the water the pressure drops right down to 0,When I turn the water off the pump will go back to 60lbs but takes along time..Any suggestions would be greatly appreciated Thanks in advance... Doug
