Big loss of pressure
Blk90s13
I changed over all my copper pipes in the upper level of my house to quick connect and now I lost pressure in both my bathroom and kitchen
I replaced the same fittings and pipe sizes with the quick connect and took all copper pipes out
Did that beacause my copper pipes were green in alot of places taped fittings and leaking elbows so I opened my basment ceiling up and went to work on them
Any idea what can I do now ? I run well water and the laundry faucet which is about 10 ft from the well gets insane pressure every thing else upstairs is just too low of pressure :mad:
thanks for your help
Mo.
What is "quick connect"? If you replaced 1/2" copper with 1/2" pex you have gone to a smaller pipe and can expect some pressure loss.
You replaced the copper just because it had some green patina on it???
quick connect fitting http://www.probite.com/ and yes I went from 1/2 copper to 1/2 pex and 3/4 copper to 3/4 pex I pretty much took out copper and put pex every where that runs my entire upper level of the house
The copper fitting were leaky and rusted ( green ) also beacause I have a well water figured the copper pipes are shot and sure enough there were very greasy on the inside we talking fresh water pipes here
If your copper was installed wrong and you replaced it with PEX the reduction of the pipes ID may have something to do with flow loss...you may have not had great flow to begin with but thought it was OK...if the problem is pressure then it is a well problem...if it is a flow problem it is most likely the PEX smaller ID causing less flow...if the ceilings are still open you may want to consider re piping differently...What is the well switch set at pressure wise...???
Copper oxidises...it does not rust...
the pressure tank on the well is set to 38 psi it works great on the laundry sink down stairs its actualy very strong you cant open it all the way it would hurt your hand but then again its about 10 ft away from the well
and right ontop of it is the kitchen sink with close to nothing its annoying me the pressure was not great to start with and when I bought the house a year ago the well service guy said my pipes are pretty clogged and I should look into switching over from copper so it does not react with the high mineral in my ground water
and you know what I meant about the copper pipe they dont rust I understand
the ceilings are all open I am actualy changing over all the sheet rock but I wont replace the pipes again I spent close to $400 on fittings and pipes that would go to junk now
I may look into a better well or even a pressure tank before I ever change the pipes
