BimmerRacer
Hey guys,
Trying to do a wall mounted faucet and a wall hanging vanity to look like this
Exterior wall is canterlivered and I already got 4" of rigid foam on the front and buttom of the bays and was planning on doing the same in the wall where the plumbing stuff will go, so that gives me R-24, which is code. The framing is 2x6".
Questions/Comments:
1. Does this work?
2. Do I need blocking which effectively will isolate the pipes from conditioned space below. Is that a good thing? Should blocking be wood, foam, or faced batts?
3. I am planning on using PEX or CPVC just to have that extra measure to allow for expansion. We are on a well and water treatment has seems to be working as I BELIEVE the current copper is 25 yo and looks fine according to the plumber who capped it.
4. IF this works I see room for supply lines as I will have 1.5" before drywall, but do I have room for the drain pipes in the wall?
Thanks
Questions/Comments:
1. Does this work?
Thanks
