Big_Bad_Juan
Six years ago, I had my jet pump replaced (1/2 hp Sta-rite, 30/50 pressure switch). I realize (now) that it is installed incorrectly, below the pipe from the well (see the pic. It was simply placed where the old pump was.) The system worked perfectly, until about a week ago, when suddenly the pressure dropped to 20 psi. This happened literally overnight. When I brushed my teeth Saturday night, the pressure was fine, when I turned on the water Sunday morning, the pressure and volume was obviously low. When I checked the pump, I found it running constantly and the pressure gauge read 20 psi. When I turn the pump on after it's been off for awhile, the pressure can get up to about 30 psi, but after I use some water, it drops to about 20 and stays there. The pump itself sounds fine, not making any new clunking noises or anything, and I've cleaned the nozzle to the venturi, so I don't think the problem is the pump. I think I can hear some air in the water when the pump is running, but I've never really listened that carefully before, so I'm not sure.
I have a neighbor who has lost prime in his pump three times this winter, the last time was the same weekend my problem started, so I'm wondering if the water in my well is low. But his wellhead is right next to a creek, and mine is probably about ten feet higher than that, so it seems odd to me that I would still have some water, and he would have none, but I'm no expert, so maybe that's possible?
I'm wondering if I could have some air trapped in the pipe where it heads towards the floor. Could that cause the problem I'm having?
One more thing - some sewer lines are being replaced on a street about 1/2 mile from my house, on the other side of the creek. My neighbor has seen them pump water out of the trenches they have dug.
I know I've rambled on for a while, so If you have read this far, thanks. Most of my knowledge about wells has come in the past week, so any thoughts about why I have suddenly lost pressure would be appreciated.
PS - The ball valve that is closed in the picture is normally open. It is closed in the picture because I was trying to see if the pressure would go up. It doesn't.
