Location for Adjustable shower bar.
Rsmith99
Oklahoma
I am installing an adjustable shower bar in my new shower. The shower will have glass on the two half walls and a glass door.
I am trying to decide where to put the shower bar. In the attached picture the blue tape indicates where the studs are in the wall. Does the bar really have to be screwed into a stud?
Where do you think the best location for the shower bar would be? I want to minimize water hitting the gap between the door and the fixed glass on the wall.
I would put it on the right side. That would provide an assist to getting in and out. By all means anchor it into a stud. I a person slipped and grabbed the bar to prevent a fall, any other mounting would tear out and the bar would be useless.
This is not a grab bar! It's an adjustable shower bar for the hand held shower (leaning in the corner of the shower).
The thing doesn't weigh much, so no, in my opinion, you don't need to screw it into the wall studs...plastic anchors should be fine. Unfortuneately, probably the best place to put it so it wouldn't hit the glass is right of the entrance. You can usually swivel the spray a fair amount, so you could be standing against the wall opposite the entrance and mostly hitting the tiled area. I say unfortuneately, because located there, it might tend to BE used as a grab bar, and you'd likely pull it from the wall, or hurt yourself or both.
bar
As far away from the door as possible, probably on the left side. Ideally, since this is a new shower the wall connection should have been off center from the control valve so the hose would not hang in front of it. And, if the hand held were going to be the only shower head, I would have put it down adjacent to the control valve.
