Hey need a connection answer
Morgan Morris
canada
We had are pipes snaked, and when they took off the cap for the clean out they stripped the threads on the cap and on the clean out stack. So i was wondering if theres a way to leave the cast iron stack and and put on a pvc cap? is there a sleeve that will go into the clean out and then i can screw the cap back on??
Thanks
Morgan
I think they make plugs that you can basically hammer in (I think they are made of lead). You'd need a new one the next time.
A Lead Fit All is probably a good choice.
co
They DID NOT strip the threads. They were already gone/destroyed before they removed the plug, which is why the probably had a hard time doing it. The lead plugs are screwed in and they make their own threads to grip whatever is left of yours.
