plumbingpros
Hi Terry (and anyone else who give us advice),
I really enjoy your forum and I've learned a lot already by reading. We are remodeling the bathroom in our 1920s bungalow, and we want to bring the washer & dryer up to the main floor, and to use the existing waterlines and drain previously used for the bath lav. We will use a 30 inch long 2 inch wide standpipe and a 2 inch p-trap (trap 12 inches from the floor measuring from the bottom of the trap). The question: we need to reduce down to 1 1/4 inch in order to utilized the galvanized reducer which goes into the cast iron dwv stack. The reducer accommodates a 1 1/4 pipe, but (I believe) it is only 1 inch inside measurement where it enters the dwv stack. Will this work for draining our washer? The distance from the trap to the galvanized reducer is 10 inches. Also, how should we best reduce to 1 1/4? 1 1/2 reducer and 1 1/2 pipe into 1 1/4 reducer then 1 1/4 pipe? Or can we just go 1 1/2 reducer directly into 1 1/4 reducer, then 1 1/4 PVC on into the galvanized? Our washer is a 3 yr old Kenmore super capacity plus top loader- just the typical whiteware. Thanks in advance for any advice you can give.
