View Full Version : Can't figure this out! Need some elec. know-how
stockwatchn
02-01-2009, 08:31 AM
My dishwasher died the other day, no power to panel. I checked the circuit breakers and reset all the GFCIs in the kitchen. Nothing. So I pulled the unit out checked the connection box (all looked good). On a whim I plugged the dishwasher into an extension cord and tried plugging it into the receptacle, just a few feet away, for the garbage disposal(which works fine). Nothing.
Then I try plugging it in across the room and BAM! I got power to the dishwasher.
Not knowing all that much about amps and volts I have concluded that the two receptacles can power low energy things like a lamp but not more demanding items like a dishwasher or space heater (i tried it). How come it worked before?
I need some education here.
Thanks Zink
jimbo
02-01-2009, 08:40 AM
First off, the garbage disposal receptacle is switched. Did you flip on the switch when tring the dishwasher?
All signs are that the receptacle your DW was plugged into is dead. If for sure all circuit breakers are on ( find the one for the DW. Flip it all the way off, then back on. A tripped breaker is not always obvious to the eye.) If the breaker is ok, then there may be a loose wire at the receptacle, or elsewhere.
stockwatchn
02-01-2009, 08:58 AM
New information: This house is just two years old so most of the electrical work is pretty new. Also, I just noticed that the dishwasher and disposal are on different circuits.
Yes, I flipped the switch on the disposal and it works fine...I also plugged in a lamp into the same receptacle which worked fine...but when I plug in the dishwasher no-go...I also plugged in a space heater there and no-go.
I rechecked the circuit breakers and flipped them back and forth and I get no power.
The one thing I haven't done yet is to check the dishwasher receptacle yet because the plummer ran the pex so tight to the dishwasher I can't get the unit all the way out. Of course I will have to disconnect the pex to get the plug back in there but I was trying to figure out this mystery first.
Chris75
02-01-2009, 09:38 AM
The receptacle is in the DW space?
stockwatchn
02-01-2009, 10:37 AM
Thanks for you help..Mystery solved
Jimbo, you were right...the fact that the disposal receptacle needs to be switched on to work gave me false results.
In the end I think a breadmaker tripped the GFCI...it took me a while to figure this out because when I pulled the dishwasher out it pulled out the plug, but the plumbing was so tight I couldn't just plug it in again after I reset the GFCI.
So I started messing around with the extension cord and disposal receptacle which caused my brain fart.
In the end I got the unit out plugged it in and voila!
Thanks for your help.
Thatguy
02-01-2009, 12:03 PM
Watch out for that breadmaker or you could be toast.:D
