Hey, I am remodeling my bathroom and have a question on sealing the threads on the shower head arm.
What I have coming up from the shower control valve is PEX, up to a Shark Bite fitting/female adapter, and into this I have screwed in the shower head arm.
Now, I used standard white Teflon tape and wrapped it around 3 turns. Once I screwed it in, I got it fairly tight...could have been a bit tighter, but the concern was that I would have turned it past being straight, and it would no longer look straight--it would be cockeyed. So I got it fairly tight but not quite as tight as I would think it needs to be.
I turned on the water and sure enough, had a very very slow drip out of that fitting.
So what do I do:
Wrap the tape 4-5 times?
Use yellow or pink tape, because it's thicker?
Use dope instead of tape?
Continue to tighten the shower head arm an additional 15-20 degrees clockwise or so to get it really tight, causing the arm to not be straight?
Thanks and be kind as I am a first time plumber & remodeler
So what do I do:
