View Full Version : Kitchen faucet bangs
BRUCEY100
01-31-2009, 10:03 AM
when ever we turn on our kitchen sink faucet it , for lack of a different word, goes bang when first turned on. It's worse and does it multiple times if I use the Brita filter option. It's not loud but is noticable No leaks underneath the sink and doesnt do it any oter faucet in our home, just the kitchen sink:confused:
quinocampa
01-31-2009, 12:03 PM
Hammer arresters are water accumulators plumbed into the copper piping near the point of use to cushion the sudden stopping of water flow. I thought it was only a phenomenon when shutting off the faucet, not turning it on? Your problem is when you open the faucet valve?
krow
01-31-2009, 12:50 PM
Is it single handle or 2 handles.?
If its 2 handles, you may have to change the cartridges
jadnashua
01-31-2009, 01:11 PM
Assuming this sink has a spray attachment, it could be the divertor might be sticking and jamming closed when yo uturn on the water. See what the pros say. What brand and model? Might be good to post a picture.
BRUCEY100
02-01-2009, 08:11 AM
First sorry I didnt get right back to you guys, seemed I had "email notification" not set:o
Anyhow it's a KOHLER K-10412 SINGLE LEVER KITCHEN SINK FAUCET. It ONLY bangs when water is turned ON.
We recently moved into this home with the faucet already there. It did it a little then but didnt think too much of it. I recently replaced "O" rings, bearings , and the cartrige in Nov '08 due to it leaking. Now getting to "little things" around here and want to know how to fix this issue.:D
Redwood
02-01-2009, 11:57 AM
This bang you get...
Is it the same sound as when you use the sprayer?
BRUCEY100
02-01-2009, 12:28 PM
BEFORE turning on the water , THIS time I picked up the sprayer , squeezed the trigger THEN turned on the water. NO BANG. just a slight double bang when sprayer trigger released. For the next 2 mins when I went to turn the water on for the regular nozle.........NO BANG AT ALL:confused:
NOW 10 mins later and STILL cannot get faucet to bang but still get slight double bang when sprayer trigger released:confused:
oh ya you asked if same bang origianl bang hard and very noticible and only 1 bang as water turned on. The double ang when sprayer used is faint and 2 bangs it seems
Redwood
02-01-2009, 12:38 PM
Check your sprayer and hose for leaks.
I believe what you are calling a bang is the diverter valve filling the sprayer hose when you turn on the faucet.
BRUCEY100
02-01-2009, 12:47 PM
So you belive the sprayer diverter is going bad?
Redwood
02-01-2009, 12:56 PM
No I believe that the pressure inside the sprayer line is draining down causing the diverter to do what it is supposed to do when you turn on the faucet.
BRUCEY100
02-01-2009, 01:16 PM
Leakdown? wheres the water going? How then do I fix this. Its the first faucet to do this and its anoying
Redwood..........Thank YOU
Redwood
02-01-2009, 05:16 PM
Is the connection fron the hose to the sprayer leaking?
Is the sprayer leaking?
It doesn't take much.
BRUCEY100
02-01-2009, 05:48 PM
Just checked and no leaking with faucet on or sprayer on. Also when sprayer was on I moved the hose around to see if it leaked. No water detected
Redwood
02-01-2009, 05:51 PM
It may just be going back through the diverter.
BRUCEY100
02-01-2009, 07:06 PM
think then the divereter is going south???
Redwood
02-01-2009, 07:11 PM
Is there any reduction in flow out of the spout when it thumps?
BRUCEY100
02-01-2009, 07:33 PM
IT only bangs when main faucet is turned on OR when sprayer's trigger is released, so I cant tell if pressure drops because of it
drthokie
02-10-2009, 07:35 AM
Hi, I just found this board and thread through a google search. Brucey, I have the exact same faucet and same issue your are experiencing. I also moved into my house a little less than 2 years ago and the faucet came with the home. I am on my third diverter valve (including the one that was in the faucet when I moved in). I have also replaced the bearings (rings) and ball that you select hot/cold water. I have contacted Kohler a few times, sometimes they are nice enough to "goodwill" the parts even though the faucet is not under warranty. When I give them these symptoms they keep telling me it is the diverter valve. I have had my most recent diverter valve in for a couple weeks now. When I replaced the 2nd with the 3rd, I could not find any difference in the two, and they are both giving my the banging. I believe the problem lies deeper than the diverter valve.
