Barlow46
Remodeling master bath in manufactured housing. Took out old garden tub in corner of bath. Still have a small shower in the opposite corner. Will be putting in new shower where tub was. Size is 64 x 46 approx. There are presently two vent stacks that go through the roof in the room. One is in the area of the toilet which is just across the short side from the existing shower. There is another vent stack in the area of the old shower. The garden tub which was 6-8 feet from the existing shower only had a p-trap with a studor valve about a foot from the drain. It was hidden under the support area of the tub. I originally planned to replace the studor valve with a through the roof 1 1/2" vent stack but then got to thinking that I may not have to. As the drain leaves the area of the studor valve, it goes about three feet and turns right and then dumps into the drain which the existing shower dumps into. Question is, Can I just leave the studor valve in the wall (with plate access) or should I put in a complete new stack for the shower. I did increase the size of the 1 1/2" drain to a 2" drain.
Thanks in advance.
Tim
Thanks in advance.
Tim
