View Full Version : Min/Max projection on a Kohler Valve
noreast
01-27-2009, 11:51 AM
Hello All!
Great board here for a wanna be DIY like myself ;)
I'm installing a Kohler k-679 Thermostatic Valve and I'm not sure where to set it? The diagram below is in the installation manual but I'm not sure where it should be set so that the trim mounts flush to the wall.
I'll be using 1/2 cement/backer board and then a 1/4 tile to finish.
Any suggestions as to whether it should be set to Min or Max?
Thanks for any advice.
George
jadnashua
01-27-2009, 04:36 PM
The easiest thing to do is install the trim on the valve before you mount it and see how much you like the handle to stick out into the shower. If the valve is mounted so it sticks too far into the shower, you won't be able to get the trim to seal (it will still flop around after you've bottomed out the screws). If it is burried too far in the wall, you won't be able to attach the trim at all (screws won't be long enough, and/or there won't be enough sticking out to attach the handle at all). As long as the finished wall falls between the min/max lines, you can attach the trim and seal things, but it's your decision on how well you like it sticking out, or close to the wall. Personally, I don't like it sticking out all the way.
C NUMB
01-27-2009, 04:42 PM
I always split the Max/Min.
http://www.city-data.com/forum/members/esplumbing-378252-albums-misc-shots-pic21971-kohler-valve-ri.jpg
That will give you a 1/2" to play with. The backer board and tile with thinset with probably be 7/8" to 1" thick.
noreast
01-29-2009, 11:59 AM
Thanks for the advice - I greatly appreciate it!
01-30-2009, 07:01 AM
IF you mess up and do not get it installed between the two dimensions, you could have a problem. If it is too far out, there are seldom "shallow installation" accessories so you have to jury rig something and live with it. Many manufacturers, but not all, make "deep installation" extensions which will usually bail you out. In most cases setting at the mid point between the two is the safest, since it accomodates both a thinner or a thicker wall than originally anticipated or specified.
