View Full Version : Shower valve - open/closed reversed
slimjones
01-26-2009, 08:46 PM
Sorry if this is a newbie question.
I had a shower valve installed by a professional plumber.
After tiling the shower stall myself, and installing the fixtures, I found that the cold water valve opens by turning clockwise and closes by turning counterclockwise. Exactly opposite of what I would expect. The hot water valve works correctly.
How can I correct this problem?
TIA - Slim
jadnashua
01-27-2009, 05:07 PM
Some manufacturers provide the valves in left-hand and right-hand versions so the handles move symmetrically. If you want both the hot and cold to turn the same way, you probably need a different brand or style. It's more noticable on a sink...to turn the water on with lever handles, you move the levers towards the spout - one going clockwise and the other counter-clockwise...same as what you have now on your shower (if I undertood you correctly). So, I don't think it is an error, it is a design decision.
Redwood
01-28-2009, 03:41 PM
What kind of handles do you have?
Knob, lever, cross....
slimjones
01-28-2009, 05:12 PM
They're cross handles. It's a Concinnity fixture.
Redwood
01-29-2009, 12:59 AM
Ohhh Boy!
I'm sorry to hear that you put that valve in your wall...
They went out of business a couple of years ago...
01-29-2009, 06:44 AM
Many "aftermarket" manufacturers send ALL faucets with the stems for lever handles which rotate the way yours does. In some cases a clip can be removed and reversed to change the rotation, but in most cases the stem has to be replaced with the proper one.
slimjones
01-29-2009, 10:09 AM
re: Concinnity - what can you do ? I bought it years ago and it is a very nice fixture. It cost me some $$ and I'm going to use it until it wears out.
I'll take a closer look at the valve and see if there's a way to reverse it.
Thanks for all the advice, this really is a great forum.
-Slimjones
01-30-2009, 07:09 AM
Depending on what controls the degree of rotation, removing the small "C" clip and installing it on the other side might do it.
