View Full Version : Removing Cast Iron Drain
jim.gary
01-26-2009, 05:30 PM
I am removing a 4" cast iron drain and replacing with PVC. Looks pretty simple, small home with crawl space. Problem is finding a 4" PVC T with a 2" tap on side for bathtub,(to match the cast iron I'm removing). Because of limited crawl space, stacking 2 Ts may be a problem. The home has one central stack for all drains.
Sounds like you're looking for the last item on p 6 or first on p. 7 here:
http://www.charlottepipe.com/Products/Assets/02C-PVC_List_Price/PVC-608A%20(1208-R1).pdf
jim.gary
01-26-2009, 06:41 PM
Thank you, That is it, now hopefully I can find it locally.
Thanks
JWG
Maybe those at the link below can point you to someone who stocks it. But you can try calling real plumbing supply houses, now that you have what it's called. Shouldn't be too uncommon at supply houses for the trade.
http://www.charlottepipe.com/Default.aspx?Page=SalesUS
