View Full Version : Septic Stains in Shower Pan
janmor58
01-26-2009, 12:16 PM
A few months ago our septic backed up. Every since then the shower pan has a stain on it that I can't get out. I've tried bleaching and scouring powders, oxyclean. Nothing has worked. I think that the pan is plastic, but it may be fiberglass. I always tape the drain up to prevent the cleaner from going down the drain and causing another problem. I sure appreciate any suggestions.
jadnashua
01-26-2009, 07:06 PM
Some people have had good luck with a Magic Eraser. If the fiberglass has microfractures in it, you may never get it clean. that's a common problem with older fiberglass stuff that was not embedded in something like concrete, plaster, etc.
janmor58
02-13-2009, 10:00 AM
WOW....thanks for the suggestion. It took about three of the "erasers" to do the job, but it took it straight off. I did not have to use any other cleansers with it either, which is great so I did not get the septic system balance messed up. THANK YOU, THANK YOU, THANK YOU!!!!
