Connectors for sockets for a Linear T5
pelf1200s
I am putting together a flourescent light fixture by using linear t5s. I have the sockets but I need neat, sleek connectors. Does anyone know where they can direct me on this?
Cheers!:)
Two points to remember.
You have to have start/run electronics appropriate to the bulbs and voltage.
The fixtures use the reflector as a ground plane. If there is not a sufficient plane at the right distance, connected to ground; the lamps probably will not work correctly.
