This is to replace a very old toilet in my basement utility room. Just like the old toilet, the new one will sit on a joist deck to allow space for the plumbing. I’m just adding a vanity and actual walls (the old one was just a toilet out in the middle of space with a sink on the wall to the left—looked like a prison cell). Unlike the old one, though, this one will be vented with an AAV (as opposed to no vent at all), and, hopefully, moved over a little. The old toilet flange was straight out from the large hub. It worked, but since space is at a premium, I’d like to move the toilet over (to roughly where the flange in the picture sits). I want to make sure the 90˚ bend is okay. Pictured next to the 90˚ is a 45˚ elbow, which might be more clog-resistant, but will also push the toilet out further than I’d really like. I also found (but didn’t buy) a 60˚ elbow, which could split the difference. So will this 90˚ work, and if not, would a 60˚ or 45˚? Thanks.
(P.S. I’m planning on keeping that shutoff and cleanout accessible through a panel, and even with the 90˚ bend, the flange will be 13†from the back wall, leaving 3 ½†between the tank and the side wall. The water discharges down under the cement floor, so I’m not willing to move the iron hub.)
