You may not need a cistern if the volume of water from the city is adequate. Check your gallons per minute with a valve wide open. If you can get 10 GPM or so, then all you need to do is boost the pressure. Then a jet pump with the Pside-kick controls is all you need. The Amtrol pressureizer would work much better and not be cycling on and off it had a Cycle Stop Valve included. I have explained this to Amtrol but, they had rather the system cycle on and off so they can sell you a larger pressure tank, and get to replace the system more often.
