American Standard Bathroom Faucet
Bakechad
Illinois
I have an American Standard bathroom faucet. I believe it is the cadet model.
This morning when I turned it on the aerator flew off into the since. I tried to screw it back on and realized the plastic threads inside the faucet were damaged.
I took the bottom plate off the faucet and found part with the threads on it and removed it. It shows part number A923300.
I searched for the part online using google and checked the diagrams at **************.com and American standard. I found the faucet, but they do not list this part in the diagram on either site. Then I went to Ace Hardware and *******. Neither of them had the part and the Danco catalog which had the diagram of the faucet did not show this part.
Am I out of luck? Do I need to just replace the faucet?
Here is a picture of the part:
Thanks
Chad
Is your faucet fairly new? Strange to see such a part made of plastic. It very likely is not a replaceable part. What model # did you come up with for your faucet? Cadet is a venerable name, and it could be from 30 years ago, or yesterday. The number on the item is just a mold mark, and most likely is not the AMSTD part #./
Obviously it is junk!
Try Moen or, Delta.
I figured my best bet was to replace. I couldn't believe it was plastic!
When I moved in there were three of these faucets. The first one failed about six months ago, this one is number two.
The house was heavily remodeled in 1998, so I am guessing that's when they were put in.
How long should a "good" faucet last?
