resident water pressure(single home)
T-N-T
I am not a plumber, I just tested my water pressure at the main entrance
outside of the carage, and it shows 110psi. From researching on this, 110psi is way too high. But I'm still not sure, This is with everything shut off, but when I turn on one of the water fixture in the house, the water pressure went down to 65psi. Do I need to ajust that 110psi to come down with everything shut down???? or am I o.k. How do I do that.
Thanks
TnT
If you've been reading here you already know this, buy an expansion tank at the same time and install that as well.
