Can someone help me, please??
What caused the loud chugging noise?![]()
Check your water pressure during the problem times.Any suggestions?
Then dye in the bowl could indicate water going around the flapper. But it could also indicate water that went over the top of the overflow tube....and I'm going to put food dye in all 3 of my toilet tanks to see if the new universal Toto flapper or the other two need replacing.
The pressure of the water should push the flapper down. Look for the flapper somehow coming down cocked to the side for some reason.I'm no plumber, but it seems that the flapper isn't sitting snug on the bottom of the tank, is this right
I replaced the flapper with the Fluidmaster flapper and it worked for a couple of months, but now the chugging has started again. More detail on the chugging after this toilet is flushed and the tank is done refilling the chugging starts, but if the sink or shower faucet is turned on again the chugging stops. So, I guess the next step is to get a new valve, but I have a question: It was recommended to me above to get a Fluidmaster valve, but shouldn't I get a Toto valve since it is a Toto toilet? I still have a new Toto universal flapper.If that does not do it, consider https://www.fluidmaster.com/products/toilet/flush-valves/540akr-3-flush-valve-with-bolts/ or https://www.korky.com/products/flus...ts/large-3-4-flush-valve-tank-bowl-gasket-kit
More work.
