Bosch DLX series dishwasher....no water flow
stevemax
Hello i have a DLX Bosch dishwasher....i took it out for a remodel project and had it on the deck covered with plastic ....when i put it back in and hooked it all up, water on, power etc. it won't flow water through the spray tubes. The power comes on and it sounds like things are turning in side but no water...any ideas or suggestions. Than ks very much...Steve
Turn the water off. There should be a supply valve where the washer line ties into the hot water to the sink. Unhook the water supply line at the washer, put the end of the hose in a bucket and turn the water on. If you have water, the blockage is in the washer. If still not water, either the shut off valve is defective or the hose is plugged.
If it was freezing outside where you stored the DW, you could have some major damage inside. There is usually some water left in it after a cycle is completed...when it expands, all hell can break out.
re. Bosch DLX
thankyou gentlemen i will try that in the bucket idea...and yes it is possible it did freeze while outside, we are in a moderate climate but it does occasionally freeze. thanks again i will check it out. Steve
You didn't by any chance use a Watts Floodsafe Dishwasher Connector when you reinstalled the dishwasher did you?
