View Full Version : Where is the bl....... pump specialist when you need one.
padd_y17
01-06-2009, 10:24 PM
I have the pump in bits the old man is due home soon and he is going to do his nana when he sees it. all i have to do is get the motor off the wet side and oil the bearings.........pls annnnnnnnnnyyyyyyyyyooooonnnnnnnnnneeeeeee ooouuuuuuuuuuuttttttt ttttttttthhhhhhhhhhhhhhheeeeeeeeeeeeeerrrrrrrrrrrr rrrrreeeeeeeeeee??????????????
Gary Slusser
01-08-2009, 09:09 PM
What type pump is it, jet or submersible? My guess is a jet because there aren't bearings in a sub. What brand? Describe what you've done so far.
speedbump
01-09-2009, 07:37 AM
Most motor bearings (good motors that is) are factory greased not oiled. Oil will not last long at all on them and for all the work involved in taking the pump and motor apart, new bearings would be a far easier solution. Most motors use 6203 bearings front and back and they are the least expensive bearing there is.
bob...
