View Full Version : Do I Need Draino?
xroad
01-06-2009, 09:57 PM
My bath room sink has been draining slower and slower. I took a peek down the drain and saw lots of black cruds. Possibly they are build ups from soap, tooth paste, and snot. I do not have this problem with my bath tub. When I replace my bath tub last year, I looked at the drain pipe and it was clean. When I replaced my sink down pipe last year, it has the same build up. A year has gone by, and it is starting to clog again. What can I use to clear this?
Gary Swart
01-06-2009, 10:31 PM
Do not use Drano or any other chemical. You have a clog and the only way to properly clear it is to have a plumber who does not have Roto in his company name clear it.
kingsotall
01-07-2009, 05:44 AM
This will also clean your pipes good but needs to be used on a regular basis:
http://www.terrylove.com/images/bio-clean.jpg
gardner
01-07-2009, 06:19 AM
Start with one of these:
http://www.zipitclean.com/
http://www.zipitclean.com/images/new_package.jpg
The ZipIt shown above is all you need to clear the drain below the sink, (my wife has been after me to use ours for the last couple of days). If there is a stoppage elsewhere then you need a snake.
tlarson
01-07-2009, 08:30 AM
Using a plumber is not the "ONLY" way to properly clear it. This sounds like a typical vanity clog, and I've cleaned many of them by simply removing the trap, tail piece, etc and then removing the hair and other build up. It may require replacing a seal or two, and needs to be done carefully, but it can be done by a DIY'er.
