Hello,
I had a pvc toilet flange installed on a concrete slab that has a metal or stainless steel ring on top...the part you attach the toilet bolts to. I had to put down a couple new tiles around the flange. My question is, should I grout right up to the top of the flange to keep the flange and the pvc drain pipe below from being able to move if the toilet for some reason shifts over a period of years and causes stress on the pvc pipe as it moves as well, or should I keep the grout away from the top of the flange more to let it keep what little movement there is in the pipe that comes up the concrete floor? Maybe a little movement or play in the pipe is okay for possible foundation shifting. Or am I over-thinking this and it doesn't matter one bit?! Thanks.
