Chrisexv6
I did a search and saw a reference to a leaking fill valve. Mine does that too, I havent tried the fix yet (pop the top off and run some water thru it to see if it needs cleaning), but its sorta related to my next question.....
What size should the "water spot" be? I notice in the bowl there is a "depression" line, and my water spot is about 1" below that line. I was wondering if maybe that line is actually supposed to be where the water spot is (because the spot seems a little low to me, but it could just be because Im used to cheaper toilets
Was also wondering if the water leaking from the fill valve into the tank instead of into the bowl could be a cause, or if its just unrelated.
-Chris
-Chris
