Tankless water supply
Mickjorr
I'm thinking about putting in a tankless hot water supply in my home. The water supply in is 1/2 inch. Will this size of supply adquately work for these kind of heaters? Thanks everyone, Mick
The size of the supply may not be a problem, but do some study on the posted threads that contain tankless...some love them, but many more don't. The temperature of your winter water supply will be an issue if it is cold, and you may not have a big enough gas line or enough power if you decide to go electric. Personally, I'd stay away from them as the cost to install and maintain means it will take many years, if ever, to recoup your investment for the foibles of a tankless system.
Here's an article recently posted by another forum user.
This is out of Consumer Reports.
Heating water accounts for up to 30 percent of the average home's energy budget. Some makers of gas-fired tankless water heaters claim their products can cut your energy costs up to half over regular storage heaters. So is it time to switch?
Probably not. Gas tankless water heaters, which use high-powered burners to quickly heat water as it runs through a heat exchanger, were 22 percent more energy efficient on average than the gas-fired storage-tank models in our tests. That translates into a savings of around $70 to $80 per year, based on 2008 national energy costs. But because they cost much more than storage water heaters, it can take up to 22 years to break even—longer than the 20-year life of many models. Moreover, our online poll of 1,200 readers revealed wide variations in installation costs, energy savings, and satisfaction.
With the help of an outside lab, we pitted Takagi and Noritz gas-fired tankless water heaters against three storage water heaters. EvenWe didn't test electric tankless heaters because many can't deliver hot water fast enough to replace a conventional water heater if ground*water is cold. in areas with warm groundwater, most homeowners would need to upgrade their electrical service to power a whole-house tankless model.
Our tests simulated daily use of 76 to 78 gallons of hot water. That's the equivalent of taking three showers, washing one laun*dry load, running the dishwasher once (six cycles), and turning on the faucet nine times, for a total of 19 draws. While that's considered heavy use compared with the standard Department of Energy test, we think it more accurately represents an average family's habits. We also ran more than 45,000 gallons of very hard water through a tanked model and a Rinnai tankless model to simulate about 11 years of regular use.
Here's what else we found:
Water runs hot and cold
Manufacturers of tankless water heaters are fond of touting their products' ability to provide an endless amount of hot water. But inconsistent water temperatures were a common complaint among our poll respondents. When you turn on the faucet, tankless models feed in some cold water to gauge how big a temperature rise is needed. If there's cool water lingering in your pipes, you'll receive a momentary "cold-water sandwich" between the old and new hot water. And a tankless water heater's burner might not ignite when you try to get just a trickle of hot water for, say, shaving.
Nor do tankless water heaters deliver hot water instantaneously. It takes time to heat the water to the target temperature, and just like storage water heaters, any cold water in the pipes needs to be pushed out. And tankless models' electric controls mean you'll also lose hot water during a power outage.
Up-front costs are high
The tankless water heaters we tested cost $800 to $1,150, compared with $300 to $480 for the regular storage-tank types. Tankless models need electrical outlets for their fan and electronics, upgraded gas pipes, and a new ventilation system. That can bring average installation costs to $1,200, compared with $300 for storage-tank models.
Tankless units might need more care
During our long-term testing, an indicator on the tankless model warned of scale buildup. We paid $334 for special valves and a plumber to flush out the water heater with vinegar. Many industry pros recommend that tankless models be serviced once a year by a qualified technician. Calcium buildup can decrease efficiency, restrict water flow, and damage tankless models. Experts suggest installing a water softener if your water hardness is above 11 grains per gallon. Ignoring this advice can shorten your warranty.
Efficient storage models are pricey
We also tested the $1,400 Vertex, a high-efficiency storage water heater by A.O. Smith. The manufacturer claims its installation costs are similar to a regular storage model. But its high cost offsets much of the roughly $70 per year the Vertex will save you. Instead, we recommend buying a conventional storage water heater with a 9- or 12-year warranty. In previous tests, we found that those models generally had thicker insulation, bigger burners or larger heating elements, and better corrosion-fighting metal rods called anodes.
Posted: September 2008 — Consumer Reports Magazine issue: October 2008
Tankless water heater
Okay, I've read enough on tankless water heaters and believe I would have problems with consistant heat. (Today it's 14 below zero ourside.) My next choice is a power vent gas water heater. My wife is concerned about the noise of the power vent. The unit will be located in the basement. I'm thinking about the Kenmore 50 gal power vent model. It has a an energy factor of .65. Looks good on paper but... Any input will be welcome. Thanks everyone, Happy New Year! Mick
I have a power vent in my basement and it is excellent. I would suggest a GE/Rheem over the Kenmore. Not sure who makes the Kenmore, but it very well may be Whirlpool and if so, that is the dog of the industry. A power vent does cost more to purchase, and if you remove the flue entirely, you are almost committed to a power vent in the future. My old (1996 Reliance heater made by Rheem) requires 4" PVC or ABS pipe to vent, and the distance was somewhat limited. The new ones can use much smaller pipe and go for longer distances.
