aa789
12-29-2008, 10:13 PM
The pipe which goes from the p-trap, through the cabinet, and into the wall has a crack which developed on the bottom.
Short of figuring out how to cut out a bigger hole around where the pipe goes through to the wall and encountering the next surprise, I was thinking of cutting the pipe a couple of inches back from the crack, and using those rubber bushings/clamps to connect what's left of the pipe to some new PVC into the p-trap. Assuming that what's left of the pipe is good, is this an OK way to go?
Also, what's the best way of cutting the pipe? I'm afraid that a pipe cutter might put enough pressure on the pipe to crack what's left of it.
Or, is there a way to fix the crack itself?
Here's a picture of the pipe into the wall, and the crack on the bottom of the pipe.
Thanks for your replies.
http://s219212006.onlinehome.us/misc/Image2.jpg
