View Full Version : Light Switch Behind Plumbing
NewTrinidad
12-29-2008, 07:22 AM
I am having the basement apartment of my 1920 row house renovated and am concerned with the way the contractor has framed the bath. Is it OK to have a light switch the opposite side of a shower faucet?
http://farm4.static.flickr.com/3127/3147756814_24c44ba9d7.jpg
http://farm4.static.flickr.com/3233/3147756902_74b8b35c0e.jpg
http://farm4.static.flickr.com/3264/3147756856_b7d7a94d7a.jpg
jwelectric
12-29-2008, 07:57 AM
There is no problem with this installation
Old Coot
12-29-2008, 11:50 AM
I'd be much more concerned about the excessive number of copper plumbing fittings and their solder joints.
Ian Gills
12-29-2008, 11:51 AM
I do not like the way the cables entering the metal wall box appear not to have been secured to it but that is not the plumber's problem.
frenchie
12-29-2008, 11:56 AM
It looks like the kind of box with integral clamps.
(google image search...)
like this:
rgsgww
12-29-2008, 04:22 PM
That conduit looks pretty bad.
Alectrician
12-29-2008, 06:40 PM
As long as you use drywall/backer board/tile....no problem.:rolleyes:
And wipe those joints next time.
Wet_Boots
12-29-2008, 07:00 PM
With a rental unit being renovated, I wonder if the old electrical work is being reviewed. That kind of BX cable often goes with 2-wire outlets.
frenchie
12-29-2008, 08:59 PM
I don't think that's conduit. Looks like old cloth-wrapped, to me. Around here, I see this mix a lot - places built in the 30's-50's, remodelled in the 60's-70's, look exactly like that picture.
I'll hazard a guess: that's a kitchen countertop outlet on the other side. Power's coming in from that cloth-wrapped wire on the left, and the BX is tapping in to run another kitchen outlet. So the kitchen looks modern-code-compliant, plenty of outlets, but there's actually only 1 circuit. You can't run a kettle at the same time as a toaster, even if they're on opposite countertops.
That's what I see a lot, anyways...
Your shower control should be screwed into a solid piece of wood, attached solidly to the studs on either side. So should that electrical box...
And wipe those joints next time. There's some debate about that, I just discovered in the plumbing forum.
It does not appear that a "plumber" installed the faucet, otherwise he would not have used the female adapters on the faucet. He would have soldered the tubing directly into the shower body, thus eliminating four potential leak points.
NewTrinidad
12-30-2008, 08:38 PM
Thanks for everyone's reply! Your comments have been very helpful.
One wire is cloth and the other is conduit. The electrical box is a light switch to the ceiling light. which is just a hallway between the bedroom and the living room. The basement apartment has not been occupied in decades and there are very few outlets so I will need to run new circuits, ESP the kitchen as one poster pointed out.
Thanks again!
frenchie
12-31-2008, 11:40 AM
So I guessed wrong, huh? :D
As long as you're going to be running new circuits, and have all the walls open, get the electrician to replace that old cloth-wrapped. It's pretty rare that the rubber insulation isn't brittle and/or damaged by now. Nothing worse than finishing the job, walls all closed up, and suddenly a circuit conks out...
