View Full Version : turning off a lamp
v1rtu0s1ty
12-22-2008, 06:05 PM
Hi folks,
I'm going to build a mini greenhouse for a plant. Inside this mini greenhouse is a 100 or 150 watt lamp. I'm looking for a cheap solution that can turn OFF this lamp when temperature inside greenhouse reaches 40F. It can also turn the lamp to ON when temp inside greenhouse goes down to 30F. I'm not really good in electrical so I don't know what to look for. Right now, I'm thinking thermostat but that's it.
Are there products like this?
jar546
12-22-2008, 06:48 PM
Hi folks,
First buy a thermometer and install it inside your house near a window that faces the greenhouse.
Next install this product and use it whenever you see the temperature at the limits you want:
http://images.savontv.com/im/nwimages/the-clapper.jpg
jar546
12-22-2008, 06:50 PM
Seriously, contact this company and just make sure that the products are UL listed.
http://www.littlegreenhouse.com/accessory/controls.shtml
v1rtu0s1ty
12-22-2008, 06:52 PM
Awesome. I will contact them tomorrow. Thanks for the link. ;)
So looking at the link, what I really need is the heating outlet. That is an awesome product!
Thanks again!
Thatguy
12-23-2008, 08:11 AM
The thermostat contacts have to be able to handle a tungsten load. If you can't find one, you need to have the tstat control a relay that can handle a tungsten load.
jimbo
12-23-2008, 08:37 AM
I will go out on a limb and say that any product which is designed to have a regular AC plug plugged in to it will be adequate for a 100 watt flood bulb. But of course, I am sure the manufacturer can provide a detailed spec sheet to be sure.
Thatguy
12-23-2008, 11:35 AM
And I will be busy sawing off the limb you are on!:p
You're probably right. This is not some huge incandescent or motor load.
