mounting stone tops on custom vanties
Chris Fox
near Phoenix AZ
I have ordered stone which is cut to CAD drawings, having never done this before what is the best way to mount the stone to vanity tops. vanities are custo mmade with corner blocks at all four corners, so there is plenty of flat surface. With plenty of flat surface to flat surface is somehtign simple as liquid nails ok for bonding?
Thanks,
Chris
It somewhat depends on whether the slab is 2cm or 3cm thick. Some stones can be stained by some glues. In the ones I've done in my home, the fabricator said just use silicon...it cushions and hold it in place. Especially if it is a 3cm slab, gravity and the silicon will hold it in place fine. You DO need to ensure that the cabinet is shimmed so the top is level, as the stone will not like it if the surface is twisted and not level.
If it is a 2cm slab, it's not a bad idea to put some plywood inserted so you have some support. Mount it on ledger boards so it is flush with the top of the cabinet.
Jim,
Its a quartz material(CeasarStone) I dotn have the specs in front of me but I am pretty sure its 2cm and it has 4 cm edge. The size is 20" x 34".
I did a little more searching since this post and silicon was recommended too. adhesive
I'd probably just glue it in place, adding ply would be for those times when the kid climbs up and decides to jump around! Probably not needed. If it were natural stone, it might be a good idea at that thickness.
Jim,
I hope my kid doesnt climb on these - their floating and hung with french cleat. I plan to reinforce with #10 screws or lag bolts into studs once its shimmed level.
