View Full Version : Broke Rheem FVIR waterheater. Please help
tankard
06-13-2005, 09:12 PM
I'm an old timer that didn't read the instructions that came with the replacement water heater I installed and I think I broke it. It's a Rheem FVIR and I covered the intake grids with a water heater blanket. I didn't say I was smart, just old. Apparently I've tripped the internal "combustion saftey system" and even after clearing away the blanket I can't get the burner to stay lit. Is there anyway to "reset" the saftey system or I'm I goosed. Thanks for any help.
T,
From what i remember from a very brief class... You are kinda cooked.I think there is a very thin piece of "burnout" wire (similar to a fuse) that when the heater is choked or flares up ,etc burns apart and will not re-light. Not sure how complicated it is to replace but it has to be done. Ain't modern engineering just GRAND ??
cal
Contact Rheem. Some FVIR units are resettable and others are a "one time" thing.
jimbo
06-14-2005, 07:45 AM
If I am not mistaken, Rheem specifically has adopted a conservative approach to the FVIR and liability issue: If an "event" takes place causing the FVIR to activate, the unit MUST be disposed of. We don't know what took place inside your unit. It still could be something repairable like the thermocouple. You need to call Rheem and have them send a qualified tech. to look at it.
tankard
06-14-2005, 09:58 PM
I went to the Rheem web site where they offer online trouble shooting manuals - for registered distributors only (rats). But elsewhere I was able to find a detailed cut-away diagram of a Rheem FVIR unit and it showed a mechanical safety that will close the air port to the combustion chamber if it is tripped (by a larger than normal flame). Using the diagram it was easy for me to open the chamber and check the safety. Indeed it was tripped and the air intake was sealed. The safety is simply a spring loaded device held open by a glass-like plug that melts in contact with a flame. It could be easily reset by replacing the melted plug. Now I need to find someone who will sell a DIYer like me the 10 cent part(probably for $20 if at all). Good luck to me.
master plumber mark
06-15-2005, 05:20 AM
I dont think yoiu can buy that plug,
I have heard from our salesman that when it or if it
ever burns out the heater is ruined....and has to be thrown away....
1. Because of the liability issue if that heater were to ab even a "possible" cause an explosion, even if the FVIR were repaired properly, no one would sell it to you unless you were a "certified" repair person..
2. This is a Rheem proprietary part so the only ones who will have it are Rheem repair technicians or the Rhemm factory.
jimbo
06-15-2005, 07:15 AM
You have indeed had what they refer to as an "event" in the FVIR system. The water heater CANNOT and MUST NOT be repaired. Contact Rheem; they may help you on a warranty basis.
jrejre
06-15-2005, 07:36 AM
You may have found this document or have other info that came with your unit. Anyway, this is the FVIR document on the Rheem web site. This does not seem to show the FVIR - but, does have the toll free number for replacement parts. Like others suggest, I'd call them and see what they have to say.
tankard
06-15-2005, 02:50 PM
Again thanks fellas for your input. It sounds like I'm going to take a big hit in the wallet one way or the other. I'll call Rheem as suggested. jrejre - I couldn't see the document you speak of and if your message has some sort of attachment, I'm new to the forum and I don't know how to view it. I'll get the numbers from their site. Hoping for a happy ending.
master plumber mark
06-15-2005, 03:26 PM
according to my rheem salesman, its toast because the
unit got above 300 deg in the chamber which can also
warp the baffle going up the chimmney and it can also
burn out the alluminum gas supply to the burner plus the
thermocoupling.......above 300deg.
they dont sell the repair parts, because of these reasons
but you might find a leaking
rhemm unit at some supply house and rob the parts off it
if they will let you,,,
no plumber (insured ones anyway) would touch this situation...
what you do yourself is at your own risk...
the only value the unit has right now
is the warranty sticker on it.
