Something Always Leaks
SteveB
I have a situation where something in my condo is always leaking. If I shut off the water to the leaking device, it just causes the leak to move somewhere else.
The only thing I can think of is the water pressure to my unit is too high. Does this make any sense?
I get a small amount of knocking when I start the laundry too.
Excessive pressure can make weak or old fixtures leak. It's fairly cheap and easy to check the pressure. You can buy a gauge at one of the big box stores or any plumbing supply store that would hook up to a hose bib, or with adapters, nearly anywhere. See what your pressure is, then get back.
Excessive pressure can make weak or old fixtures leak...See what your pressure is, then get back.
Thanks for the help. The gauge says my water pressure is a little over 140 psi, which I understand to be way too high.
YIKES!!!!!!!
Anything over 80 psi.Have your association people get a plumber ASAP!
And...good job paying attention where no one else seems to have! Your saving the building.
