View Full Version : Basement backed up.. desperately need advice my wife is going to kill me
aluminex
11-15-2008, 09:31 AM
I am in desperate need of some good advice and direction.
My wife and I purchased a house recently and the previous home owner is deceased. We have our washer and dryer in the basement and that is our main issue.
The drain goes under the basement floor and it actually has a few drain holes throughout the basement. Everytime my wife washes clothes the water backs up and comes up out of the drain holes into our basement. Sometimes she can wash 1 load.. sometimes 3 or 4 before it backs up.
How can I find out where the drain is stopped?
There is a possibility the drain was covered on the other end when we had our driveway installed but I can't be sure. How can I find out where the drain ends if it's covered up?
Cookie
11-15-2008, 09:58 AM
The one thing I do is to use copper sulfate in my outside drain.
I would do this after I got the clog out. I buy my sulfate crystals at where else, Home D.
I do the sulfate twice a year and it helps in keeping out the tree roots on mine.
http://www.drainsandplumbing.com/sewerdraincleaning.html
http://www.oldbridgechem.com/CuSO4.html
11-15-2008, 10:11 AM
You may want to bring in a plumber with a snake so he can clear the lines.
If it's roots downline, those can be treated later.
First you need to getting it running again.
Cookie
11-15-2008, 10:16 AM
I used ... Rooter, twice in years gone by, and I never had a problem with them, and, the bills were reasonable. Since, the last time, I had to have the drain declogged, I have been using copper sulfate and no more root problems. Well, at least for me, my clog were roots from some very large, 90 foot trees.
Gary Swart
11-15-2008, 10:19 AM
The most likely problem is a clogged drain line. You should call a plumber who do not have Rooter as part of his name, to auger the line. It is possible that roots could be partly to blame, but the first step is to clean the line. Do not even consider chemical drain openers or DIY snakes. The auger needed for the job is large and can be very dangerous for a novice to use. You probably couldn't even get one in the first place. Chemicals will only create a hazard for the plumber when you eventually call him. This is not to say that some products intended to keep roots out of the line might not be effective after the line is cleared would not work, but first they need to be cut out and the line cleared all the way to the end.
Cookie
11-15-2008, 10:24 AM
I maybe wouldn't use the one with Rooter in his name, lol, for other things... but, they are good for drains, I used them. NOW, on the other hand, I had some mighty fine plumbers in here for other things, where I had direly, wished I had used the other guy with Rooter in his name. Seriously. Not all is bad, not all is ever good.
Since, I have used the copper sulfate OUTSIDE in the drain, never inside I have been virtually clog-free. WHAT a relief. It is horrible when you have to bang your clothes on a rock to clean them, :D
aluminex
11-15-2008, 02:32 PM
The problem may be my clogged drain line but I have no idea where the actual line goes and I'm concerned when I had my driveway built we covered it over with dirt.. is this possible?
Would it be feasible to assume the drain was just going outside into the ditch?
jadnashua
11-15-2008, 03:27 PM
It's possible, but probably not up to code. I'm assuming you don't have sewers and are on a septic system?
kingsotall
11-15-2008, 08:39 PM
Seeing that you just bought the house it would be extremely beneficial to hire a plumber to not only clear the drain but flil you in on the questions you have on your plumbing system.
Redwood
11-15-2008, 11:26 PM
Copper sulfate root killer is illegal to use in CT, CO and the following counties in CA: Alameda, Napa, Santa Clara, Contra Costa, San Francisco, Solano, Marin, San Mateo, Sonoma.
We use Root-X.
http://www.rootx.com/
If the house is was built before 1975 or if you know that your drain pipes are not PVC I would also have a camera run down the drain if he pulls back any roots.
nhmaster
11-16-2008, 05:04 AM
I have a suspicion that the laundry drains into the basement perimeter drain.
aluminex
11-16-2008, 05:49 AM
perimeter drain?
Cookie
11-16-2008, 06:01 AM
We use Root-X.
I checked your link and clicked on what it does, and oddly, it says:
DOES NOT HARM TREES OR PLANTS... Is not a root a tree part? :confused:
http://www.rootx.com/files/Images/comparison_chart.jpg
Cookie
11-16-2008, 06:17 AM
The main chemical is dichlobenil. Yikes. Don't go sniffing it.
http://www.pesticide.org/dichlobenil.pdf
http://www.wsdot.wa.gov/Maintenance/pdf/dichlobenil.pdf
Mode of Action
Dichlobenil molecules are taken up by roots
and transported throughout the plant.3 Inside
the plant, dichlobenil inhibits actively dividing
cells by disrupting the formation of the cell plate,
a structure which forms during cell division to
separate the two new cells.4
So, it tells me, that chart to the link is WRONG. This is bad stuff and homeowners and plumbers are using it thinking it is not thanks to the great state of Ca.
Infact, this may actually apply:
http://www.epa.gov/opp00001/foia/affirmation.htm
jar546
11-16-2008, 07:01 AM
Bingo
Since you don't know where it goes why not just connect your laundry waste into your plumbing waste pipe. Probably a lot cheaper than screwing around with cameras and everything else.
Redwood
11-16-2008, 10:14 AM
Cookie I don't make the laws.
Copper sulfate is well documented as its toxicity to fish and other aquatic wildlife.
I sewer line treated with Root-X does not kill the tree where copper sulfate may.
The reason the copper sulfate was a concern in those areas is the emissions from water treatment plants of copper sulfate was exceeding the maximum allowed by the EPA.
Cookie
11-16-2008, 11:51 AM
What? I thought you made that law!:D
I was just pointing out that RootX is really not any better than copper sulfate, and it is pretty documented in those links. Why the great state of Ca does what it does only those in charge knows the reasons why. But, it is nice when the people knows some of the truth. It is really misleading the public to think one is safer than the next. Just my 2 cents worth for what it is worth to anyone.
God, I wish I made the laws.
http://smileys.smileycentral.com/cat/4/4_1_203.gif All plumbers would get free chocolate chip cookies at their local bakery.
http://www.smileycentral.com/sig.jsp?pc=ZSzeb097&pp=ZK (http://smiley.smileycentral.com/download/index.jhtml?partner=ZSzeb097_ZK&utm_id=7925)
construct30
11-16-2008, 11:53 AM
Bingo
I would get some one to clean it with a camera and locator. If it does go into the perimeter drain or french drain as we call it here, I would get it figured out. If that drain is plugged it could cause other problems and still needs to be fixed.
aluminex
11-16-2008, 12:30 PM
Bingo
Would this be hard for me to do or should I hire a plumber?
I haven't worked much with plumbing but is this a project I should try on my own?
construct30
11-16-2008, 12:41 PM
The short answer is call a pro if you have no experience.
Unless you really pick things up quick and like learning new things. It will take a lot to learn from nothing how to do this let alone it can be dangerous if not done properly. Depending on where you live it might require a permit, most places allow homeowners to work on their own house, some don't, which is really unconstitutional according to some people.
I would figure out if the basement drains are plugged before you end up with a foot of water in your basement. It might run slow now, but if it plugs completely you will have trouble.
Cookie
11-16-2008, 01:27 PM
Just a suggestion, maybe, more a thought since I am not a plumber, but, what about getting it jetted instead of using a snake? I would think that line would be cast iron and if like mine full of rust. Just my 2 cents worth. :) Also, if a washer, could be a lint problem too?
Like Terry said...have it snaked and like I said...if they pull back roots get a camera down there and see whats up.
