new flooring raises height-- new toilet flange
Lee Polowczuk
Florida
I am putting a new hardwood floor in my bathroom...
i had to put down 5/8" underlayment and then 5/8" hardwood...
so now I am 1 1/8 inches higher.. that's not quite true... i removed a tile floor...
is there a recommendation to make the toilet fit... the old flange appears ok...but the bolts won't be long enough for the toilet...plus they appear rusted.
this toilet has been in for 19 years...
Thanks...
lee
What's underneath the new stuff? Concrete slab, wooden subfloor, a basement, finished ceiling?
The proper place for the flange is on TOP of the finished floor and bolted through it into the subflooring.
How far below the floor is it?
concrete slab
I will have to measure: i think a half inch to 5/8" probably a half...or about the height of a standard tile
There are two ways you can go. You can do a hack job with ring extenders and/or extra wax rings and pray, or you do it right and hire a plumber to properly install a new flange that will rest on top of the finished floor.
I have elected to use a ring extender.. the kit comes with two gaskets..i will use on gasket on the underside mating it to the existing ring.
I will then use some tapcons to tie the two together...
then of course the wax ring
