MikeVila
When using the transition cement for use of ABS to PVC just use a cleaner and then the cement on both? Don't use any purple primer correct? I believe ABS you can't use the purple primer? So just clean thoroughly and cement?
TOO many codes lol. It's not being inspected so is there any problem with using it? Not gonna fall apart is it? lol. I never knew plumbing was such a PITA. They make transition cement but it's not allowed by code? They make S traps and there in my lavatory sinks and kitchen sinks but there not allowed.LOL This stuff is driving me nuts!!!![]()
abs/pvc transition cement, brown label
green, medium body, fast set, For joining ABS to PVC pipe, and, fittings up to 6" diameter, non pressure only. Schedules 40 and 80.
Meets ASTM D3138
MSDS #65
UPC and NSF approved.
ABS to PVC Transition Green Cement
Medium-bodied green colored cement for use in joining ABS to PVC in non-pressure transition joints.
All schedules up to 6" diameter pipe and fittings.
Recommended application temperature 40°F to 100°F.
Meets ASTM D-3138.
They do have a disclaimer on the submittal sheet that some codes do not allow its use.
http://www.oatey.com/apps/catalog/i...bmittal_Sheet/ABS to PVC Transition Green.pdf
