Looking to replace 4 toilets
EdF
Hi, I was hoping I could get a recommendation on some new toilets.
I moved into a new home about six months ago and unfortunately, there are some fairly cheap toilets in the house. When you flush them, the water comes down at high speed from multiple areas and creates a lot of splash back. All the water comes from the side, there is no jet hole at the bottom. The splash back will be on the seat and sometimes on the floor. Needless to say, this is not what I want from a toilet. (I keep the lid closed when I flush but sometimes visitors do not).
Anyway, I'm looking for a standard looking toilet with elongated bowl (2 piece). Probably with a 1.6L tank.
My main objective is to find a toilet that flushes with no splash back and does the job.
Any recommendations would be much appreciated. I've seen some post about the Toto Drake but am confused as to which model to look at. Their website has quite a few Drake models.
http://terrylove.biz/7-toto
If Drake is the suggestion, is there alot of water that comes down the side or is it primarily under water action thus no splash back? Are there any videos of the flush action?
Thanks so much for any help!
The Drake is a very popular model because
Quality control,
Very good flush
No spash back
Ease of assembly.
Drake with 1.6 gallon flush
CST743S, Regular bowl, 14-1/2" high bowl
CST744S, Elongated bowl
CST744SG, Eongated with CEFIONTECT
CST744SL, ADA Elongated with taller bowl, 16-1/2" high
EcoDrake with 1.28 gallon flush
CST743E, Regular bowl, 14-1/2" high bowl
CST744E, Elongated bowl
CST744EG, Eongated with CEFIONTECT
CST744EL, ADA Elongated with taller bowl, 16-1/2" high
Thanks Terry, so looking at the CST744SG, is it worth the extra few buck for the CEFIONTECT?
Also, is the majority of the flusing power underwater or does it come down the sides?
Wander over to Toto's site and read their stuff on CEFIONTECT. Basically, it is a smoother, anti-microial glaze...stuff has a hard time sticking to it. I find it much eaiser to clean when needed (not as often) - no hard scrubbing...just a quick pass. It is far more common in Europe and the far-east.
Most of the flush action is below the surface. The surface kind of drops away.
I think the extra for the CEFIONTECT is worth it, it's a long term investment.
