Just moved into a new house with a new drilled well. The well was drilled about six weeks ago. We moved in about four weeks ago and are getting a fair amount of grit that is causing problems with our washing machine....it has clogged the inlet screens twice so far and the flow slows to a trickle while filling the washer.
I called the well company and was told to let the water run from the spigot just under the pressure tank for a few hours to let things clear up.
I am thinking about installing a spin down filter to help with the grit. Is this a good idea? At least the spin down can be flushed out without having to replace a filter. I was thinking of a 100 or 140 mesh filter. Does the spin down filter get installed after the pressure tank, or before? I'm thinking after, but wanted to double check.
