View Full Version : Drain Pipe Coming Up Through The Floor of Shower
abovethewake
10-28-2008, 12:24 AM
We are buying a home that was built in the 1975, is single story and sits on a concrete slab. The drain pipe of one of the showers is sticking up through the floor of the shower. The shower is fiberglass and the drain pipe does not have a grate on it. It looks to be 2" ABS. Anyone know a good, simple way to fix this?
Redwood
10-28-2008, 05:46 AM
Could you post a picture of what you have?
10-28-2008, 06:32 AM
cutting it off will solve the symptom. The real question, and maybe problem, is why it is sticking up out of the floor.
jadnashua
10-28-2008, 10:50 AM
If they didn't bed the fiberglass shower pan in something solid (like mortar), over the years, it could have flexed and gradually, the floor sagged while the drain line stayed where it was and is now sticking up into the drooping pan. For this to happen, you'd be breaking the glass in the fiberglass, and it loses much of its strength, gets that crazed look, and could start to leak if it doesn't end up breaking. Fiberglass can't handle repeated flexure...you need to have it supported.
abovethewake
10-28-2008, 05:03 PM
Thanks for replying. I have a picture, but, I don't know how I can attach it. Any pointers on getting that done?
abovethewake
10-28-2008, 05:04 PM
I did not see any cracks, even tiny ones, in the floor.
abovethewake
10-28-2008, 05:11 PM
I've thought about cutting off the pipe with a Dremel and using this fix it. http://www.plumbrite.com/?PHPSESSID=890a18c0cee3a87977f03dea28d4e5d2
What do you think?
Redwood
10-28-2008, 07:58 PM
To upload a picture click on the paper clip on the post reply screen.
abovethewake
10-29-2008, 09:55 PM
I have attached a picture of the drain. Thanks again!
